The construction of an triode, by hand
[Claude Paillard] is truly talented. He makes triodes by hand. This is a long and arduous process that has many steps, each of which could be messed up pretty easily. [Claude] makes it look easy though.
You might recognize this from way back in 2009 when we covered it on hackaday.com
[thanks for the tip David]
Your email address will not be published. Required fields are marked *
