No space in the garage? Build a Lamborghini in the basement
lambo
It took 17 years, but [Ken Imhoff] finally got the car of his dreams. This isn’t a, ‘go down to the dealership’ situation. No, [Ken] built a Lamborghini Countach by himself in his basement.
The build process started off by fabricating a wooden frame to which hand-crafted aluminum panels were attached. The frame of the car was welded out of tubular steel, and slowly, over the course of 17 years, a custom Lamborghini Countach took shape.
When the car was complete, there was one problem left to solve – how do you get a car out of a basement? Rent a backhoe and knock out a wall, of course. Replacing a few cinder blocks in a properly reinforced wall is a lot easier than cutting a Lambo chassis in half, it seems.
It’s an amazing piece of artistry that is a testament to [Ken]’s skill in metalworking, welding, and pretty much any other skill we can think of.
Your email address will not be published. Required fields are marked *
