Incredible bow lathe work in Morocco
Bow lathes are a fairly old an simple contraption. A bow is used to rotate a block of wood back and forth while tools can be used to shape it, just like a modern lathe. Despite the fact that the wood is oscillating instead of spinning in one direction, the results are very smooth.
Watch as this street vendor shows his skills with the bow lathe. I find it quite impressive how well he uses his foot. You can tell he’s been doing this for a very long time. I was also pleasantly surprised when that ring popped free, I wasn’t expecting it.
[thanks Rudolph]
Your email address will not be published. Required fields are marked *
