Copper kettle just for the hipster coffee scene
04-copper-kettle
Handmade coffee is a feature we need to write. But for now we present this copper kettle which is designed to pour out the boiling water very slowly in order to achieve the perfect cup of slow-drip java.
[CHS] made the kettle for his friend [Nate]. The entire process starts off with an arc of flat copper sheet which makes a slightly conical cylinder when curved until the two ends meet. Getting a water tight seal on this seam is imperative and it took four or five tries to reach perfection.
To get the kettle in shape [CHS] improvised a mandrel out of a thin slice of railroad track. After polishing it smooth it goes on the inside of the copper and gives him something to hammer against. We think this step is magic… It’s kind of like the old sculpting adage that you remove everything that isn’t what you’re trying to end up with. The beauty of the piece really pops out as the final curves are hammered into the work.
Your email address will not be published. Required fields are marked *
